Rendering color differences
jharding86
jharding86
When I render something out in Fusion 360 the rendering preview looks really good (the way I would expect it), when the render completes it seems to be applying this weird orange hue. I have used this same background in the past without this happening, is it possible one of the recent updates made a change?
In the render preview:
During RenderingDuring Rendering
After the render has finished:
After rendering has completedAfter rendering has completed
jlcreations3d
The update back in April hosed rendering color accuracy for me (I render in colored plastics mostly).  Cloud renderer works correctly as does in-canvas renderer, but the local rendering engine applies what looks like a bad snapchat filter to intensify the colors of my renders to the point of them looking like cartoons.  I hate having the use the in-canvas renderer as I cannot queue things up, so it's not a solution, but I've seen nothing in the updates to suggest a fix.  Love to get more attention to this problem as it single-threads my time in my workflow for every product.
jacobsr0100
Community Visitor
Community Visitor
It sounds like the issue you're experiencing with Fusion 360 might be related to changes in the software following a recent update. The orange hue you're noticing in the final render, despite the preview looking correct, could be due to several factors. It's possible that the update altered some default settings related to the lighting or material properties, which are now affecting the final output. Another possibility is that the environment settings or background image might be interacting differently with the new rendering engine, causing unexpected color shifts. I recommend checking the environment settings, lighting, and material properties in your project to ensure they're set as intended. If the issue persists, it might be helpful to reach out to Autodesk support or check community forums to see if others have experienced similar issues after the update.
