Fusion - Render crash
onlytezonly
Message 1 of 10
onlytezonly
Fusion 360 is consistently crashing (shutdown/no blue screen) with event viewer showing Critical Event 41 Kernel-Power, when I go select the preview render on a model. I have a G733PYVAS laptop (AMD 7945HX & 4090). The crash causes my laptop to be semi bricked for a while as it crashes as soon as i log into windows many times and following crashes when simply web browsing (never happened before the render crash).
This post has been edited due to: @lauri_barnhart added the product to the title to help more community members find this topic.
Replies (9)
Message 2 of 10
namehelp06
Observer
Observer
Hi @onlytezonly , can you share the specific model that causes the crash? Or is it with any model into the render workspace?
Message 3 of 10
onlytezonly
I did not have any crashes previous to this one that bricked my computer and had previously rendered a file with many of the same components several times in a different file save. Unfortunately, I need my computer functional for the time being so I can't test more. https://a360.co/49JfHGf
Message 4 of 10
onlytezonly
Let me know how to attach the f3z file if needed.
I keep getting:
Correct the highlighted errors and try again.
  • The attachment's 1slimboi_crashexe.f3z content type (application/fusion) does not match its file extension and has been removed.
The file is 32000 KB
Message 5 of 10
namehelp06
Observer
Observer
Hi @onlytezonly , First export the file from fusion, then right click on the .f3d file and compress to .zip file and then you should be able to send it.
Message 6 of 10
onlytezonly
Message 7 of 10
namehelp06
Observer
Observer
Hi @onlytezonly , I played around with the f3d file and after trying to render and preview render(Which I am assuming you meant "In canvas render"), I had no issues, You said it crashes when you hit the preview render right ?, If possible could you attach a short video of what exactly leads to a crash as I was unable to reproduce it.
Thanks!
Message 8 of 10
onlytezonly
Tested on a similar system? I did a complete new windows 11 install with fresh drivers and fresh install of fusion. https://youtu.be/aKFMEsuWs-w?si=02Qzyh2k46hGPgCJ
Message 9 of 10
heather_tracy
Hi @onlytezonly,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Heather | Community Manager
Message 10 of 10
onlytezonly
Thanks for checking in. No solution yet, still waiting for a response.
