@carl.j.barker wrote:
@aparna_naik
This was reported on the insider forum 8 months ago. Try FDWG-18692, there may be more info
Hi there,
Not quite sure what this means sorry. I looked up DWG-18692 and all I found was a forum post with people moaning about how bad fusion is in general (lol). Something similar was mentioned but I think this seems to be a different issue?
I am able to rename in all other workspaces but drawing, including home. When I type in the rename box while in drawing workspace, it looks as if it is still the drawing window that is active and hotkeys are being pressed (e.g., I press D and i can see the dimension button in the toolbar highlighted). Sometime this issue does not occur when I have a new/simple drawing. I've noticed it happens most on complex drawings in large folders. I've had this issue across multiple operating systems, fusion versions, and Autodesk accounts so I don't think it is a problem with this pc/account/install specifically.
If this is covered by FDWG-18692 then disregard everything I say I suppose, but if not, I would really like to see this fixed. It does cause quite a bit of annoyance and It seems like something that would be an easy fix given that it's not an issue in other workspaces.
