remove lines on a design/completely close gaps.
hello, im very new to fusion but have never had this problem before, i used to use inkscape to draw something and convert to svg, but recently i have been using adobe illustrator and when i extrude its like the gaps on the lines are not fully closed and its effecting my prints, i hope i word this okay to understand. all i do is select the part i want to extrude, use new body for the outline and then join for the rest.  what am i doing wrong? my ai files are correctly converted to svg.
Stuart-H
Trim shortens the line and extend lengthens them to a target line , simples as the meerkat says
you have the command in fusion to do it but why not design in fusion360 and save importing problems
Mac Studio M1Max and MacBook Pro M1
i like adobe illustrator much better thats why. im quite new to fusion would it be possible to explain how i would do what you have mentioned?
Stuart-H
Have a gander here
https://youtu.be/x9l-bJvnVR8
Look around 31.20 mins
he shows it better than I could
the whole vid is worth a look plenty of good info
Stuart
TrippyLighting
There are a number of educational resources you should take advantage of. Start but not ending with the Learn & Support section of this forum.
g-andresen
If you mark "error places" in the screenshots and additionally upload* the fusion file we could better see where the problems are.
günther
* Please upload the file:
File > export > save as f3d locally  > attach it to the next post.
