Remapping shortcut keys to mouse buttons
tim.brammer00
tim.brammer00
Good evening,
I'm quite new to Fusion 360. I recently bought a mouse with extra buttons and now I am wondering if it is possible to map some of the shortcuts to these buttons? For example, it would be really helpful if I could carry out the "measure" command using one of the buttons on the mouse instead of the "i" key.
The mouse is a Logitech mouse and I am running the Program on a MacBook.
Tim
jhackney1972
Normally you would use the Logitech mouse application to assign commands to your mouse.  It either came with this application or you can download it from the Logitech website.
John Hackney, Retired
lance.carocci
The challenge with "extra button" mice and keyboards is that those key inputs are generally only recognized by the device's driver, before being forwarded as a keystroke/click/event that the OS can recognize.
While a lot of applications support Mouse Button 1-3, and often 4/5, anything beyond that is not part of any interface standard; similar limitations exist with keyboards that have macro keys, too.
The workaround for this is generally to map those buttons to a function the OS can recognize, such as an existing key or button. An example of this would be binding "Mouse Button 26" to "s" so that both S on the keyboard and MB26 trigger the search box. If you were to unbind S from Search, MB26 would stop working, too, since you're now just mimicking an unbound hotkey.
Logitech Options software supports creating a custom profile for any executable, so you should be able to set up a highly customized set of mouse-based shortcuts, without impacting any non-Fusion workflows.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
alanf156
Community Visitor
Community Visitor
Thank you for that helpful reply!
marshhome
I have a Logitec 3 button mouse and find by default, the middle button depressed gives me pan.  The third button on OnShape gave me orbit which was incredibly useful.  Can I instruct Fusion to recognise the third button to action orbit?
lance.carocci
Try setting Fusion's Pan/Zoom/Orbit shortcuts to "Solidworks" within the General section of application Preferences.
Lance Carocci
marshhome
Dear Lance,  thank you very very very much for your advice. Solidworks didn't do the job but Tinkercad did.  Nw I can get on with it!
