- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would consider this a bug, but in any case it is problematic for me.
I have a design that has an component that is parameterized to be some number of rows and columns of a unit size.
I change the rows and columns parameters and 3D print that variant of the component.
Here is a simple example showing a body with 2 columns and 3 rows.
The pattern is the combine of the foot being joined to the block. The block is always row by columns of a unit size. Everything works fine until I want to create a model with only 1 row or 1 column. This is the smallest version of the model and requires no actual patterning of the combine, which I believe should work.
However, if I set either rows or columns to zero then the pattern become an error shown in the timeline.
I can still print the 3D body at the new size.
But,
Most of the time the error clears when the rows and columns are changed and both greater than 1.
However, there are times when I have sent a model to the printer and after it printed realized that the pattern was changed (I don't know when it happens) and the count for one of the axis of the pattern had disappeared.
