Recovery Document in Different Team
kglasnappWDHTJ
Message 1 of 12
kglasnappWDHTJ
I am getting an error message when trying to recover an import document.
Cannot open the following recovery documents because they are located in a different Team. Switch to the corresponding Team to open the recovery document.
Any help would be appriciated
Replies (11)
Message 2 of 12
kglasnappWDHTJ
I only have one team -- so how can I switch to a differnt team????
Message 3 of 12
akshay_kakade
Hello @kglasnappWDHTJ
Greetings!
              Could you please Refer and Try steps in help document Fusion Help | Switch between hubs | Autodesk ?
Hope steps in documents will help you to find hub you are looking for.
also, could you please DM me your email ID you are using for login?
Thank you
Akshay Kakade
Message 4 of 12
kglasnappWDHTJ
My email for Fusion is kglasnapp@gmail.com
When I do find hubs I get;
Join a Hub We couldn't find any hubs that you might like to join based on your email address.
If you know the name of a hub youd like to join, contact its administrator for an invitation.
Message 5 of 12
akshay_kakade
Hi @kglasnappWDHTJ
Could you please check your DM Inbox ?
I have shared info for login .
Thank you
Message 6 of 12
kglasnappWDHTJ
Sorry but nothing I have tried has worked.
Message 7 of 12
cmelojr
I am having the same issue. I remember there was an update that forced some sort of necessity to use these teams? Seems to have broken using recovery files that were taken before that. Really frustrating. My laptop crashes a lot and sometimes I don't realize what broke until awhile later when opening a document. Now I've lost something that I wouldn't have if it weren't for this update.
Message 8 of 12
akshay_kakade
Hi @kglasnappWDHTJ
Could you please refer Article about Fusion Team upgrade.
Moving to fully featured hubs in Autodesk Fusion
Message 9 of 12
kglasnappWDHTJ
It still fails when I try to recover the old document that was created before I upgraded to Hubs.
How can I access the old unrecovered document?
I have upgraded to the latest version of Fusion.
Message 10 of 12
akshay_kakade
Hello
Could you please refer Article How to find recovery files in Autodesk Fusion  ?
Hope it will help to recover your document .
Thanks and Regards,
Akshay Kakade
Message 11 of 12
kglasnappWDHTJ
Thanks so much for solving my problem. You can close the ticket.
Keith Glasnapp
Message 12 of 12
akshay_kakade
@kglasnappWDHTJ
Good to know problem solved with article "How to find recovery files in Autodesk Fusion "
Could you please click on Accept solution, it will help other users to refer this current post for similar issues .
Thank you and we wish good luck for your projects with Fusion 360.
Akshay Kakade
