Radius leader frustration
mlangN8XKB
mlangN8XKB
Perhaps I'm missing something but I can't extend the radius dim leader line and keep the leader pointed to actuall geometry of the radius I'm dimensioning.
Anyone?
jhackney1972
You are correct, Fusion 360 does not have radius dimension leader extension.  You can however use the new Sketch function to create the extension lines.  In my Screencast I placed a full circle extension.  If you would like, you can also use the trim tools to make it a partial curve as shown below.
John Hackney, Retired
nemadec
@mlangN8XKB
I tried this issue and getting correct radius leader for both the circular entities (Refer Image)
Can you share some more info about geometry?
It would be great if you can share the file.
Chandrashekhar Nemade
Sr. SQA Engineer
mlangN8XKB
Outside radius work fine. Try an inside radius. It won't let you extend the leader very far before jumping off the actual geometry seemingly based on extending past the rad center.
