"Sign in" does not open browser to complete Fusion sign-in process
eirini.malegiannaki
Message 1 of 21
eirini.malegiannaki
I am using macOS Monterey, how can I fix this issue?
Replies (20)
Message 2 of 21
RajkumarIlanchelian
@eirini.malegiannaki Can you please do the following?
1. IF you change your default browser to another one does that launch the browser?
IF that does not help:
1. Go to Launch pad - Run Fusion service utility
2. Run the Gather system info
Please attach the zip files that it generates here.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 21
eirini.malegiannaki
I tried change the default browser but it didn’t work. When I run Gather system info, the app does not respond.
You can find attached the Autodesk Fusion 360 file in zip format of the Application Support that I found manually.
Eirini
Message 4 of 21
RajkumarIlanchelian
@eirini.malegiannaki I do not see any attachments. Can you collect the manual logs following these instructions?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-manually-co...
Will need the application and service logs.
Autodesk Fusion
Join Fusion Insider
Message 5 of 21
eirini.malegiannaki
Are these all the logs?
Message 6 of 21
RajkumarIlanchelian
@eirini.malegiannaki Still dont see the logs. Can you email it to me directly? [email protected]
Autodesk Fusion
Join Fusion Insider
Message 7 of 21
eirini.malegiannaki
I just did it. Let me know if you received them.
Eirini
Message 8 of 21
RajkumarIlanchelian
@eirini.malegiannaki I have not yet received any emails. Are you adding thee to a zip file before you post? Can you try to post the files here again?
Autodesk Fusion
Join Fusion Insider
Message 9 of 21
eirini.malegiannaki
Here is the zip file.
Message 10 of 21
eirini.malegiannaki
@RajkumarIlanchelian Here is the zip file.
Message 11 of 21
eirini.malegiannaki
Zip file
Message 12 of 21
RajkumarIlanchelian
@eirini.malegiannaki I got the email and this attachment. Thank you. looking at it now.
Autodesk Fusion
Join Fusion Insider
Message 13 of 21
RajkumarIlanchelian
@eirini.malegiannaki Can you please close Fusion and any other Autoesk products and then install Autodesk Identity from here - https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/z0hbzhTNDhtrN6D0LZl5b.html
This should address the issue.
Autodesk Fusion
Join Fusion Insider
Message 14 of 21
eirini.malegiannaki
@RajkumarIlanchelian I followed this process. This time I have "Connecting to Autodesk" but it does not respond.
Message 15 of 21
RajkumarIlanchelian
@eirini.malegiannaki Can you please restart your machine and try again? If this continues then we will have to look at network issues.
So if this repeats after a restart of the machine, new logs will help.
Autodesk Fusion
Join Fusion Insider
Message 16 of 21
eirini.malegiannaki
I already did this but the situation is the same. Here are the logs.
Message 17 of 21
RajkumarIlanchelian
@eirini.malegiannaki Thank you. Looking at the new logs.
Autodesk Fusion
Join Fusion Insider
Message 18 of 21
RajkumarIlanchelian
@eirini.malegiannaki Can you please try the below?
  1. Close Fusion
  2. Go to Finder - Go - Go to folder - type this exactly -  /private/tmp
  3. For this tmp folder – Get info
  4. Sharing and permissions – Is your user account having write permissions? If not can you add write permissions?
Autodesk Fusion
Join Fusion Insider
Message 19 of 21
eirini.malegiannaki
Yes, my user account does have write permissions.
Message 20 of 21
RajkumarIlanchelian
@eirini.malegiannaki In the tmp folder can you please delete the folder Autodesk-IDSDK-IPC and then start Fusion again?
Autodesk Fusion
Join Fusion Insider
