"Paste New" functioning but not "Paste"
ronhof
Message 1 of 9
ronhof
I am trying to copy a component from one file to another, I want them to be linked, so I can continue to edit the original component in its file, and have it change in the other files as well.
I have done this before with a component and it is linked to the new file - but now I want to do the same with other components from other files than the first linked file.  in other words I have copied one component from file 1 to file 2 and now want to copy a component from file 3 to file 2 - this I can not do with Paste only with new Paste ? why don't I get the option ? if I go into the top menu line under Edit and choose paste there - nothing happens !
Replies (8)
Message 2 of 9
TheCADWhisperer
@ronhof
Do you have the original Component as a separate *.f3d file in your Data Pnnel?
Message 3 of 9
jhackney1972
Copy a component from one file and then using Paste to add it to another is not possible and as far as I know, has never been.  You can Save the Component to the Cloud and Insert into the Current Design as a linked file.  You can also Save to the Cloud and then Derive it into another file.
John Hackney, Retired
Message 4 of 9
HughesTooling
Derive might do what you are describing.
Mark Hughes
Owner, Hughes Tooling
Message 5 of 9
TrippyLighting
I think @HughesTooling is correct, but I would recommend that you share your designs and explain in more detail what you want to accomplish.
"Derive" is powerful functionality and should only be used when really necessary.
Message 6 of 9
ronhof
It works - I marked the component - then save copy as - and placed this in the same folder, as than my main project was in. Then found it there, right clicked on it and Saved into current design - (Paste would be easier !!)
Thank's.  Kim
Message 7 of 9
ronhof
Have not tried it as saving it in the cloud and insert into current design worked well
Message 8 of 9
HughesTooling
The component will no longer be linked to the original design if you use save copy as. If you use derive you can get a copy of a component that's still linked to the source design.
Mark
Mark Hughes
Message 9 of 9
ronhof
well I did get a link but could not test it, as I had a problem with an earlier link, that muks up my project if I try to synchronise them -so I'll wait and test it later
