In the attached screen-cast, I am trying to split a face with an edge by point insertion. It can be split by insert edge, but I want to split it with point insertion. It doesn't work, except in diagonal orientation.
→→ I copy paste the body into a whole new document, and point insertion works again as it should.
Note:
- It doesn't work if I save, close and reopen
- It doesn't work if I export / the entire file
- It doesn't work if I export the component to which the body belongs, or any parent component
- It doesn't work if I copy-paste the component to which the body belongs, or any parent component
- It only works if I copy-paste the body itself.
By being forced to do so I lose the structure of the document.
I have seen other (similar) glitches with Pull, where instead of pulling the geometry on the closest object, it does it on a seemingly random point of an unrelated object far away, even if target mode is set to manual.
Pasting the bodies (t-spline model and mesh target) into a whole new document solves the problem.
Are they known issues / have they been documented before?
Thank you.
