"Error calculating stock" - Simulation Crash
pete.oxenham
Message 1 of 31
pete.oxenham
Fusion keeps crashing, simulation shows: "Error calculating stock". No clue why this is happening, but it started with the most recent update.
Pete Oxenham
Chatter.dev
Replies (30)
Message 2 of 31
Lennart_Losjo
Hi.
Can you attach a screen shot of your stock settings or better, provide the Fusion-file.
Senior Product Specialist
Fusion 360, Inventor.
Message 3 of 31
seth.madore
@pete.oxenham do you have the Preview Flag "reduce air cutting in 3D Adaptive" turned on? Try turning that off and see if you can get past this error.
Seth Madore
Message 4 of 31
fbarreda777
Hello, i have the same issue of @pete.oxenham, if i try to simulate the whole program it crashes or show the error "An error has occurred during a stock calculation", it's a program for 4th axis mill. i have another complain, the some operations to have their toolpath generated are taking too long, i understand that 3d adaptative cleaning take a lot of the computer but, about 300 seconds (checked by Fusion cam task manager) to be completed an operation it's too much time, all that issues came with the updates. Waiting for response of you guys because i'm stuck without the simulation.
Message 5 of 31
Having the same issue. Any ideas on this would be great.
Message 6 of 31
skrupaNR4Y5
I have the same problem. There is so much bug in Fusion360... I really don't know if Inventor 2021 works better.
On a Core i7-8700 CPU, camkernel take 8 hours to just calculate 200 curved lines in 5 axis...
Message 7 of 31
iwokowanski
Same here 😞
Message 8 of 31
seth.madore
To all those that have replied, do you have a file that you can share?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 9 of 31
PiotrKawka
Observer
Observer
Hi Seth,
I am getting the error message under setup 1, T4  3mm Groove. If you can have a look and let me know why I am getting this notification.
Wayne.
Message 10 of 31
david.mcdonald6GYJG
I'm having the exact same problem!!! This has crippled my ability to program parts.
Message 11 of 31
cahustonFPZWB
Same issue here. My positive experiences with fusion are becoming few and far between
Message 12 of 31
skrupaNR4Y5
I give you an example of simulation crash.
I just change the tool. And if I choose another tool he will generate random toolpath in first path for no reason (see my post: https://forums.autodesk.com/t5/fusion-360-manufacture/mutli-axis-contour-doesn-t-follow-curve-line/m... )
What are all this bugs ?! Possible to have a developper who can fix this strange bugs ?
Message 13 of 31
hadleyMHDZ7
Same problem, just posting to keep aware of thread
Message 14 of 31
Same issue, can't simulate a very simple lathe program that was proofed and posted some weeks ago.
Message 15 of 31
seth.madore
@Anonymous can you share this file that's not simulating?
Seth Madore
Message 16 of 31
forgeperformance
Hi, also having this issue.
Seems to fail on stock when a groving operation is performed
Message 17 of 31
seth.madore
Please share the file:
Seth Madore
Message 18 of 31
PiotrKawka
Observer
Observer
Hi Seth,
I attached a file with this error and have not received any feedback yet, the error seems to occur on grooving operations within lathe components.
Message 19 of 31
seth.madore
@PiotrKawka okay, thanks, that issue is still present in a newer build (upcoming release build). I did find that by making BOTH the "Overall Length" and "Head Length" the same value allowed me to simulate.
I will open a ticket this morning on this issue
Seth Madore
Message 20 of 31
jwleaman
Observer
Observer
I had this issue to, and will explained how I fixed it.  It's pretty alarming that an update caused this issue.  Will I be able to trust F360 to open my files in the future?  Also alarming is the lack of detail in the error message.  "Error Calculating Stock".... Not a great place to dive in from.
My setup had a stock calculated from multiple bodies.  I was able to fix this by copying the existing bodies to a new group, combining them into a single body and setting this new 'simplified' body as the stock for my setup.  Good luck.
