- Mute
- Permalink
- Report
Hi Autodesk experts.
I'm trying to get better at using fusion as some of my customers are using it. So I've been doing some designing in fusion rather than Solidworks for a change lately and something that's really bugging me is that often I will create a feature (in the solid body design workspace) such as a Chamfer or Rectangular pattern or even a simple hole feature and I'll go select a bunch of edges or faces or sketch geometry and it works. But then I need to go back in and change my geometry selection as the design evolves. I click edit feature and the feature properties box opens but it will never let me actually make changes. I find have to delete, then re-create, a whole new feature from scratch with my new geometry selections (if I wanted to remove some of the selected geometry).
If I want to add just few bits of extra geometry to the feature I can't just go in and select a couple more edges or faces either. I'm left with the same option as above or creating a whole new feature just for the extra few bits of geometry that I want to add.
This leads to a rather long and confusing design history tree and a whole lot of wasted time to get there.
I'm hoping I'm just being daft and overlooking some simple trick that someone could please point out to me.
Thanks team!!
Dan
