Message 1 of 12
05:52 AM
- Mute
- Permalink
- Report
I'm assigning a User Parameter to a Joint, as its rotation value. When I click "Compute All" to update the rotation value (changing the user parameter value does not update automatically), the assignation of that parameter to the joint is removed. This happens to all the joints in the document, if there are multiple.
Steps to reproduce:
1-Create a simple hinge Joint between two components and a parameter of type deg and value of 90º
2-Assign the parameter to the Rotation of the joint
3-Click Modify->Compute All(Ctrl+B)
4-Check the Rotation value, the parameter is no longer assigned
Version info:
2.0.10356
Windows 10 (19043)
