Quick edit ribs
Quick edit ribs
Flowh64
Quick edit ribs
Flowh64
Do you plan to introduce the modification of the ribs by double clicking on the object, as in the video below at 4:02 min?
https://www.youtube.com/watch?v=MUQ_KAzkKXQ
Thanks.
dsouzasujay
Hi @Flowh64
We cant double click and quick edit dimensions today in Fusion 360, but we should be able to edit the sketch dimensions in design workspace.
Here is how we can do:
https://knowledge.autodesk.com/community/screencast/d5a0fdb8-15e6-4233-929f-9e3202da7cc8
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Flowh64
Yes precisely it is to avoid going into the sketch. It's fast, powerful and
life-changing for the designer 😉
If for the moment it does not exist, thank you for confirming what I see,
will it be one day, or does it seem ridiculous to you?
Thanks.
TrippyLighting
In the browser you can right-click on the sketch and enable "show dimensions".
the sketch needs to be unhidden so see the dimensions.
Then you can edit the dimensions just by double clicking on the dimensions.
This is not as quick or convenient as the functionality in SW.
You might want to edit the title of the thread to "Quick edit dimensions"
