Question About a Construction Plane That Does Not Exist on The Browser But Appears in The Design
Nicholas_hagg
Observer Observer
Nicholas_hagg
Observer
Observer
Hi Everyone,
I was modeling today and encountered a strange bug that I cannot seem to solve. At some point, I created a construction plane by accident and when I attempted to delete it, the plane did not delete itself. Instead, it is still in the design, and I can still interact with it, although when I select it all of my components and bodies are also selected, similar to if I select the entire design. I does go away when I hide the construction plane but doesn't go away when I select hide all planes or if I select hide all edges, only when I hide the folder itself. It's really hindering my workflow, and I was just wondering if anyone has run into a similar issue before. I've already closed and reopened both fusion and the file with no change, and the issue also exists when I export the file as a f3z and open it in fusion. I've attached a few images and can try to upload the full model if people think it's necessary, although it's a fairly large file so I'm unsure if the forum will accept the file. I am happy to answer any questions anyone has.
(PS Please ignore my lack of naming things organization is not my strong suit)
meowthy_art
Community Visitor
Community Visitor
Experiencing this bug as well. I tried a bunch of things like clearing my cache and I still can't get rid of the plane.
TheCADWhisperer
@Nicholas_hagg
@meowthy_art
Can you File>Export your *.f3d file that exhibits this behavior to your local drive and then Attach it here to a Reply?
Nicholas_hagg
Observer
Observer
Unfortunately, the file size is too large to attach here. I tired compressing it but with no luck. If you have a good way of sharing it let me know, I'm happy to try anything. @meowthy_art also may have better luck attaching it
Nicholas_hagg
Observer
Observer
Okay, so I do have an update. As I was working on the part today (trying to work around the plane) and fusion ended up buffering for about 30 minutes so I force-closed it. When I reopened fusion 360, I reload the model from the most recent autosave and the plane was gone. I should mention that the autosave was made well after the plane was added to the design, so I genuinely do not know how it disappeared. I do still have a copy with the plane still in that I can share if there is a way to do so, but apparently that solved the issue. If anyway has an explanation, I'm all ears.
TheCADWhisperer
@Nicholas_hagg
Are you using personal license or are you using commercial license?
If using commercial license, you can post a link.
If you are using personal license, you can send to the file to thecadwhispereratgmaildotcom and I will take a look.
