QtWebEngineProcess.exe blocked by avast
designer_TT1
designer_TT1
When I opened up Fusion 360 today, Avast blocked QtWebEngineProcess.exe, which is located in appdata/local/autodesk/webdeploy/production/xxxxxxxxxxxxxxx/
It says infected with PDF.Generic, Behavior Shield.
jhackney1972
Well I did a virus check on that particular file on my system and it showed nothing unusual.  I have two suggestions, you can save your existing file with a .bak extension and replace with the one in my attached zip file or you can add an exception to Avast Anti-Virus.  I would do the first one.  If you do make sure that Fusion 360 is "completely" closed, not processes running before you do it.  If you run a virus check on the file I am sending you, I can guarantee the fault lies with Avast and I would make an exception rule.
John Hackney, Retired
