Qt6Widgets.dll was not found after repair/reinstall
macmccaskie
macmccaskie
Please, I need help getting fusion working again.
I'm getting errors trying to run fusion after I started the service repair utility in Fusion.
Details:
-->started the service repair, it got to about 45%, then is stopped with permissions issues and told me to stop the python.exe processes.
-->I did that and the service repair utility closed.
-->Then Fusion would not start and I got several  *.dll not found errors.
-->I downloaded "Fusion Client Downloader.exe" to hopefully reinstall and repair it.
-->Got these error messages attached as files
Please help me get fusion going again, thanks.
jhackney1972
Take a look at this Forum Post Solution and follow it to the letter.  Also make sure you have sufficient rights to your computer to install applications.  The process is assuming you are using a Windows based computer, if not, please ignore.
John Hackney, Retired
macmccaskie
Thank you for the link.  This same thing happened several weeks ago and like then, the install is stuck at "preparing your experience."
The dogs are waiting for their walk and when we return I expect it will still be stuck at "preparing your experience."  I'll kill that screen and probably be running again.
I had hoped there was a better solution, but thanks.
