Project with Construction not working anymore.
HarrisonClassic
HarrisonClassic
I think a bug has crept in.
When creating a sketch and projecting a face with construction lines turned on, the resulting geometry is not construction lines.
David Harrison
Harrison Classic Boats
Win 10 / I7-11700K @ 4.9GHz / 64Gb RAM / SSD's
jeff_strater
hmm... it works in a simple case.  I'm not sure what is different, though.  Can you see anything?
(view in My Videos)
Jeff Strater
Engineering Director
HughesTooling
It does this if you  have Auto Project enabled. @jeff_strater I noticed if you project the face into a sketch with auto project enabled you end up with a single outline, in the past you used to end up with 2 sets of lines. The new way is definitely an improvement, when did it change? @HarrisonClassic Most users turn auto project off because it tends to project more than you need and adds clutter to the sketch.
Mark Hughes
Owner, Hughes Tooling
