Program version for macOS HIGH SIERRA 10.13.6
Message 1 of 9
Hello!
You can give a version of the installation file program running on macos High Sierra 10.13.6
There is no possibility to update macOS to a newer one.
Thank you!
Replies (8)
Message 2 of 9
dsouzasujay
Hi @Anonymous ,
Did you give a try installing Fusion 360 on macOS High Sierra?
I see other forum post says they were able to install.
Let me know if the installation worked.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 3 of 9
Here. This is the latest version of the installation file.
Message 4 of 9
dsouzasujay
Hi @Anonymous ,
Can you please send me the Installation log files from below location.
macOS:
  • Macintosh HD>Users>***>Library>Logs>autodesk.webdeploy.streamer.log
Let's see what we can do here.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 5 of 9
Yes
Message 6 of 9
hoegge
These do not show how to run on High Sierra. The current Fusion said it could not run and I had to install, and then when installing, it said I cannot run it on this os. That means I have to toss a perfectly fine 27" iMac with plenty of power for Fusion? This shows that the cloud and subscription model does not work that well, and will increase the amount of waste and overuse of resources.
Message 7 of 9
dav.sacris
Community Visitor
Community Visitor
Bonjour comment installer fusion sur high sierra 10.13.6 ?
Merci
Message 8 of 9
hoegge
This way AutoDesk actually contributes to increased waste and environmental problems, by not supporting perfectly fine hardware.
Message 9 of 9
upreality3d
Community Visitor
Community Visitor
does not work. please provide a download link to previous installs of this software.
