program stock all times
Hello I still have a problem using FUSION 360. The program freezes constantly, especially if you need a command that the program cannot apply, but also on simple commands it does, such as shifting or working on faces. I think I have a nice computer so I'm surprised that I have such a difficult job. I use RYZENA 9 3900x and GPU rx 5700xt + 32GB RAM. Can you do anything because it is not possible that the computer was too weak, and the program hangs every few seconds to the point that it is not responding and I need to shut it down over and over again.
jhackney1972
Can you post a Fusion 360 file that is causing these issues with your system for others to troubleshoot and test.  Sometimes certain modeling methods cause such issues.
John Hackney, Retired
ok, this is the file
jhackney1972
Your model is not real complicated and open for me very quickly and is very responsive.  I was expecting a lot a lag and unresponsiveness which I did not see.  One guess, go to your Help icon and then select Support and Diagnostics and then the Graphics Diagnostics and make sure Fusion 360 is using your graphics card correctly.
You didn't get me right. The project starts well and usually responds quickly, but it can hang a lot when issuing commands. Please open my file (let BODY kadlub 1 be visible) select from the BODIES tab for example stat1 and click on it once in the drawing (select it with the cursor) and click on the MODIFY tab MOVE / COPY option and then enter in the MOVE table in the yDISTANCE field value 100. What effect? I have dozens of seconds jammed.
I use several computers and it is similar in every case
all computers use appropriate graphics cards, which are visible in diagnostics. Thank you for your help but the problem is still there.
