Hi @info4F99P
Thanks for posting! This is a known performance issue - you are trying to move 1861 bodies simultaneously, which will put a large load on Fusion 360 and likely cause it to hang for some time. If the move command is going through after Fusion is unresponsive for only about a minute, I would call that a win.
What are you using the PCB model for? If the PCB is built of standard/ordered components and you are trying to visualize it in a mechanical assembly, you could simply use the outer box of the component for sizing and remove nearly all the detail.
I also notice that the 244-82180-1000-A01-07-31-15_ASM and 244-82180-1000-A03-10-12-15_ASM are both included in the JETSON-NEW_ASM component - separating these out into two components will reduce the load on the move command, you'll just need to perform it twice.
The resources below as give some tips on simplifying files like this:
I've also seen some past issues in which copying all the bodies into the top level component of the design and removing the subcomponents helps with this type of performance issue. One way to do this is to save a copy of the problem component in SAT format after right clicking it in your assembly and selecting "Save Copy As." Unfortunately this did not help much with later move commands in my tests, which indicates that this amount of data is at the limit of what Fusion can move simultaneously.
The development teams are always working to improve performance with large datasets like this and I've added your file as an example on their ticket. I appreciate you bringing this to my attention.
Paul Clauss
Product Support Specialist
