Product Update Required
cmud4247p1
cmud4247p1
Hello. It says:
Product update required
Fusion can't open ____ which was persisted by version 2606.1.33 with your current software version 2605.1.52.
I did all  of the reccomended troubleshooting options. Here is the log file: What do I do?
RajkumarIlanchelian
@cmud4247p1 Go into Fusion - Help - support and diagnostics - check for live update - it should prompt that there is an update available. This should update you to the latest version.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
cmud4247p1
@RajkumarIlanchelian It says I don't have internet connection, even though I do and I'm literally sending this from the same computer.
RajkumarIlanchelian
@cmud4247p1 If you have not can you please do the following?
1. Log out of Fusion
2. Close Fusion
3. make sure that it is not running in task manager
4. Restart the machine
5. Login to Fusion and truth live update again?
If it does not work, can you if possible connect your machine to say your mobile hotspot and see if it now notices network?
Autodesk Fusion
Join Fusion Insider
cmud4247p1
Sorry for the late response, but I am still getting the same issue even when using hotspot. It still says I dont have internet. This is odd because when i create other projects, I can save them and they still save to the cloud.
RajkumarIlanchelian
@cmud4247p1 Can you please do the below?
1. Logout of Fusion and close Fusion
2. Go to Add/remove program - Selection Fusion - change
3. This will launch the Fusion service utility
4. Run the repair Fusion
5. This will reinstall Fusion and launch it
Now does it all work? If it does not then
Go back to Fusion service utility and run the gather system info. This will generate a Fusiondiagnosticsdata.zip file. Please post that here.
Autodesk Fusion
Join Fusion Insider
lauri_barnhart
Hello, @cmud4247p1,
Just checking in—did the responses shared by @RajkumarIlanchelian help clarify your question?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Lauri | Community Manager
