Problems with Fusion since last update.
Nickwnet
Observer Observer
Nickwnet
Observer
Observer
Since the last update Fusion has not run properly, started with not being able to see the panel showing my libraries, so I couldn't move projects from editable to read only.
Then it would not start, showing in Task Manager as Not Resonding.
Uninstalled and tried to reinstall, same problem, Not Responding.
Finally received a message that there were files that Fusion was trying to access that were in use by another process and to post the log file here.
Any help would be appreciated.
Thanks, Nick
jhackney1972
Your log file shows that you have a Permissions problem.
Take a look at the Autodesk webpage for some help.
I would suggest also to check your credentials and be sure you are an Administrator on your system.  Also, after cleaning up you system, when you reinstall, make sure you Right Click on the installer and select "Run as Administrator".
John Hackney, Retired
