Problems exporting plans from 123D MAKE
Not that long ago I was able to export pdf files of plans in 123D Make. Now whenever I try to export, it tells me "To export your plans, you must sign in to the Community."
I am logged in and have registered with the Education Community.
Any idea how I can fix this issue? I have some students who are needing to export their plans for a calculus class.
Thanks in advance!
Snortimer
 I can't say for sure if this is your problem, but the 123D Apps have been discontinued, including 123D Make. It's possible that it's not logging in properly because of that.
The new replacement for 123D Make is "Slicer for Fusion 360." You don't actually need Fusion 360 to use it, though. Here's a link to it: https://apps.autodesk.com/FUSION/en/Detail/Index?id=8699194120463301363&os=Win64&appLang=en
Good luck!
Thank you for letting people know this! I have been trying to export for two hours now!!!! Hope the Fusion will do the job. 🙂
Thanks so much for your response. Do you know if there is a replacement for 123D Catch? I also use that software in my project.
Snortimer
Autodesk has Remake and ReCap 360, but those are desktop apps, and I don't think there's a Mac version of either (which may not matter for you, but does for me).
However, I downloaded Trnio on my iPhone and it seems to have similar functionality to 123D Catch.
It's still stupid that 123D make doesn't say that is discontinue. The error message you get is please login to Community, what that even means.
