Problem with white anti-aliasing on image capture and screen display
Paul_Stary
Paul_Stary
I find anti-aliasing counter-productive on anything with a dark background, as the anti-aliasing artifacts that are created are white. This looks worse in most cases than turning anti-aliasing off.
Here is a magnified corner of my model without AA, a sign with a graphic (decal) applied.
Without Anti-AliasingWithout Anti-Aliasing
Here is the same corner with AA. Note the white dots and lines added to the borders.
With Anti-AliasingWith Anti-Aliasing
Here is the full model, a triple-screen display system with image decals applied to the screens and graphic panels above. The anti-aliasing is horrible and cannot be used for these images.
A closeup...
Is there a way to change the color of the AA effect? If not, does it make sense to add this option or am I missing something about how AA works?
Thanks.
paul.clauss
Hi @Paul_Stary
Thanks for posting! It looks like you are experiencing a known issue with anti-aliasing in Fusion 360. This behavior has also been described on this forum thread, and is logged internally as FUS-34544. We appreciate your input on this behavior!
Unfortunately, apart from avoiding the use of anti-aliasing, there is not a great solution for this behavior at this time. I've made a note of your comments on our development teams ticket on this behavior in hopes of increasing the priority. Please let me know if you have any questions - I am happy to assist. I think the idea to define a color for anti-aliasing would be a great addition to the Fusion 360 Ideastation
Paul Clauss
Product Support Specialist
Beyondforce
Hi @paul.clauss
Is the Anti-Aliasing only depends on the F360 Anti-Aliasing feature capabilities or does it also depends on the Graphics Card?
In other words, How much the Graphics card can improve on the Anti-Aliasing?
My Graphics card is AMD Radeon Pro WX 7100 and if I'll switch it to something else will it help?
Cheers / Ben
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
