Problem with share links.
HughesTooling
Consultant Consultant
HughesTooling
Whenever I click a share link in a post, for example this post. I get this page and don't seem to have any option to view the shared part.
I can view my own links but any I've tried on the forum don't work.
Mark
Mark Hughes
Owner, Hughes Tooling
ryan.bales
Autodesk Support
Autodesk Support
I'm seeing the same thing but i'm not sure. @karina.harper and i passed some links to eachother not via forums and its working just fine.
Here is another test: https://a360.co/2PwBjui
Ryan Bales
Fusion 360 Product Support
HughesTooling
At home now and I can view the design you linked and the one from the thread I linked to above so not sure if it's something that was a temporary problem. I'll check again tomorrow at work.
Thanks Mark
Mark Hughes
HughesTooling
@ryan.bales  Back at work and can't view your share like or any others. One thought is I've blocked several urls in my router to stop adds and other junk, don't suppose any of these are needed? Other than that the only difference between home and work is the ISP.
Mark
Mark Hughes
ryan.bales
Autodesk Support
Autodesk Support
I would not block amazonaws. That is likely the sole culprit. Have a look here:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
Ryan Bales
HughesTooling
I'm pretty sure I blocked it because of annoying adds so I'll just have to put up with no share links. Think I had some problems with dodgy adds on eBay redirecting to other sites and there's no way to report to eBay. Some info here.
Mark
Mark Hughes
