Problem with post processor
I am using an old NUM750 cnc controller, and I am having sometimes problems with G02 and G03 commands.
This controller does not understand if both x and y values are not present after G02 or G03.
I am using post processor NUM. How can I force it to write always both X and Y values, even if one does not change from previous command?
Accepted solutions (3)
Tomek.G
Hi @Anonymous,
You can simple add an forcing routine at the beginig of the onCircular() function like below
function onCircular(clockwise, cx, cy, cz, x, y, z, feed) {
  xOutput.reset();
  yOutput.reset();
Tomek.G
Sr. Technical Consultant
Great! Thank you very much! I will try it.
Question:
-Can I force also z-values in it , in case of circular interpolation in another plane by just adding
zOutput.reset();
Tomek.G
Hi @Anonymous,
sure you can!
Or you can use function
forceXYZ();
to force all (XYZ) in one line.
Tomek.G
serge.quiblier
Hello @Anonymous
For your information, the NUM library post had been updated for several potential issues on circular interpolation.
(XYZ should no be modal, as IJK)
We should not generate a negative radii for arc over 180 degrees....
Have a nice day
Regards.
Serge.Q
cam.autodesk.com
