Problem with installing Fusion 360 on a Mac
Message 1 of 25
Hi all,
I have a situation on my mac OS.
After downloading the Fusion 360, I had to just Right Click>Open to install.
The Mac has no issue that the file was from the Internet. Unfortunately once I click open it the icon disappears.
Does any one know why this is happening, and how to fix it?
Replies (24)
Message 2 of 25
James.Youmatz
Autodesk Support
Autodesk Support
HI @Anonymous,
Welcome to the Fusion 360 Community!
Just to get this straight - you download the client downloader from the internet, you double click to run the .dmg file which then prompts you to right-click and open the Fusion icon in order to start the install, is that correct? Then after you hit open, nothing happens? Is there a hidden dialog that pops up? I know on my Mac a window pops up notifying me that this is from an unidentified developer and I need to hit OK to continue. Then, after I hit the OK button, the Fusion Install window pops up.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 3 of 25
Thanks for your responce James,
You have it right, that I get to the unidentified developer and I need to hit OK to continue. Then, after I hit the OK button, the Right-click>open to install icon disappears and nothig else happens.
Any suggestions?
Message 4 of 25
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Have you tried restarting your Mac and then trying? I wonder if there is a dead process in the Activity Monitor. A restart should clear this up.
Also, in your security settings for the Mac, do you have the preference to allow apps to be downloaded from identified developers?
James Youmatz
Message 5 of 25
Hi James,
Yes I have done several restarts, but still no success.
As for security preference that will allow apps to be downloaded from identified developers, there is no problems there either.
Message 6 of 25
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Let's set some time up next week to go over this together. Do you mind emailing me at [email protected]? I would love to remote in and get a first hand glance as to what is going on as I am pretty stumped myself. I would like to monitor Activity Monitor to see even if the streamer process launches once you hit OK.
James Youmatz
Message 7 of 25
Problem solved, needed an update on the OS.
Message 8 of 25
I'm still having this issue with my MAC, I have restated the computer (many times) and I have follow the steps in the previous message and I just get this error log file.
So I will attach the log file and hope that this has a solution.
@James.Youmatz wrote:
Hi @Anonymous,
Message 9 of 25
I'm having this exact issue. I've restarted my computer, updated it and made sure the privacy settings were correct. My mac is an OSX Yosemite version 10.10, is this too old for the fusion program?
Message 10 of 25
pos_tur
Community Visitor
Community Visitor
Thanks! Restarting my mac worked for me 🙂
Thank you for solving my problem you beautiful ****.
Best Regards
Feiti Rúnkar Bergsson
Message 11 of 25
i'm having problems installing on my mac. my OS is Big Sur 11.2.1. Ive tried restarting, ive even tried using file from my laptop - which installed ok, but no luck on my desktop?
Message 12 of 25
I deleted my Fushion 360 as I installed it again. It says that You already have the latest version of Fusion 360 installed on this system. Would you like to start Fusion 360? When I type Yes it disappeared and nothing happened.
Message 13 of 25
lew.satur
Observer
Observer
Hi, I am having this same issue.  Using OS 10.13.6
I download the client downloader from the internet, I double click to run the .dmg file which then prompts me to right-click and open the Fusion icon in order to start the install, it verifies the image then, a message pops up saying if I want to open an application from the Internet and I click Open, then nothing happens.
I've restarted numerous times, I've disabled anti-virus, but nothing..
Any assistance would be great
Message 14 of 25
Hi
I had a voyage of discovery and ended up deleting files as directed from support pages from ‘Hidden’ files on my Mac. I had to google to find out how. Once this was done I ran the installer again and now everything works fine.
Hope that helps
Message 15 of 25
g-andresen
Take a look at the system requirements.
günther
Message 16 of 25
lew.satur
Observer
Observer
Hi @Anonymous. Appreciate your guidance... I guess that explains it.. perhaps I should have looked there first.
Message 17 of 25
I downloaded the fusion client downloader, pressed right-click to open. and it always comes up an error could not install. i need help
Message 18 of 25
g-andresen
which OS (+ version) ?
günther
Message 19 of 25
MacOS High Sierra
MacBook Air (13-inch, 2017)
Version 10.13.6
Message 20 of 25
2327923
Community Visitor
Community Visitor
I am experiencing this exact problem. Did you manage to find the solution?
