problem with face/body selection
I found this problem occurs quite often, not sure it is a bug or feature, so when I select a face or a body, it will automatically select the bigger one which usually behind the face that I intend to select. it seems that the selection is based on size priority, so every time the face I want to select didn't appear, I need to hold the left mouse to select it from the menu, that's kinda inconvenient when you have to do it frequently. Any solution to solve this problem? thanks!
Rushikesh.kadam
@Anonymous can you try again by unselecting the option 'Select Through' under the selection filters?
If my reply was helpful, please click the "Accept as Solution" or the “Like” button. This helps others to find the answer more quickly!
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
Thanks! problem solved.
Rushikesh.kadam
Happy to hear it solved your problem. Do post on Forum if you have any more questions.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
