Problem with assembly (Pls Help me)
a4136FGSW4
a4136FGSW4
I'm an F1 in Schools competitor and I built a car body as well as it's components (wings, wheels, etc) as different projects because that's required. Then I started another project and used the Joint tool to put them all together. I did that so I could test my car for aerodynamics on Autodesk CFD, but when I tried to import the file (.stl) to the software it said that "facets are not well connected.
After some experiences I came to the conclusion that the problem is the way I assembled the car. When I tried to import only the car body it worked, but as soon as I started adding the components I stopped working, that's how I got to that conclusion.
I tried using the Align tool and it doesn't work as well.
I really don't know what to do now. I tried to do the tube air test directly on Fusion and the car doesn't appear on the simulation.
Can someone pls help me?? I´m running out of time and no one answers my questions here :').
Thanks for the time.
g-andresen
Without insight into the design (file), any hint of possible sources of error is pure speculation.
günther
a4136FGSW4
Oh my bad, thought I had attached the file but didn't.
Here it is.
Thanks for answering btw
