Problem when saving STLs
lcjnsb
lcjnsb
When I save an stl the name requested is not what is saved. It gets copied 3 times ie; if I save a file called 'Table support v2 v8' it will prompt me to save 'Table support v2 v8.stl'. When I click Save I end up with file named 'Table support v2 v8_Table support v2 v8_Body1_Table support v2 v8.stl' .  I am using the latest version, 2.2.9305 on an Education Lic.
TheCADWhisperer
lcjnsb
The file is attached, but it is not this file. The problem started with the
last update and happen to all files exported as STL.
TheCADWhisperer
No file Attached?
lcjnsb
Here is file you requested, but like I said it happens with all files.
TheCADWhisperer
Can you create a Screencast Recording of what you see?
This is what I see...
The file saves with exactly the name that I assign.  (See Attached.)
Are you on Windows OS or are you on Mac?
lcjnsb
On testing today (11/7/2020 ) it saves correctly, I want to thank all for the help, Was probably a Microsoft Windows problem, I did have an update between the time I reported this and now.
