Problem using cura 4.5
I've been using Fusion 360 quite successfully for a couple of years, using Cura slicing software and have produced some excellent prints. A couple of days ago, I was prompted to download the latest version of Cura, Cura 4.5. Since then, in F360, click to 3-D print, and select, it then shows a dropdown to link to Cura, click on that and it then goes no further, it appears as though it is not recognising the latest update. Has anyone else experienced this, and if so can you advise me as to a fix? Thanks, Ken H
MoshiurRashid
Select "custom" instead of Cura and then locate the program file of cura and select the exe file of cura.
See if it works or not.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
JeromeBriot
You can also try my free add-in 3D Print Plus that supports Cura 4.5.
A new version will be released in a couple of days to support the upcoming version of Cura (4.6)
