Problem Installing Fusion 360
danielcorlett83
Message 1 of 10
danielcorlett83
Hi guys just looking for a bit of help. I have been stuck in offline mode for a few quite a few months ( it could trick it some times into connecting if i tethered my phone to my desktop). After a while i got sick of it and eventually fixed it buy following one of the suggestions here on the forum by making the folder un-hidden. This fixed the issue but then broke Fusions ability to perform any sort of update. I then performed a clean uninstall but now I'm unable to re install Fusion, could someone with more knowledge than me have a look at the log file Fusion has spat out and point me in the right direction?
Things i have tried are disabling my firewall, anti virus and running the installation as the admin. Other than that i have know idea.
Regards Dan
Replies (9)
Message 2 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Hi @danielcorlett83,
Welcome to the Fusion 360 Community!
I believe your proxy server is coming into play here and prohibiting Fusion from reaching the correct servers. As you can see in the code snippet:
urllib.error.URLError: <urlopen error <urlopen error [Errno 11001] getaddrinfo failed>, url:https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f7a6f4a289729f/full.json>
2017-09-24 17:21:36,523 - MainProcess(3984) - InstallDriver - adsk.dls.streamer.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2017-09-24 17:21:36,525 - MainProcess(3984) - InstallDriver - adsk.dls.streamer.process - INFO :: S_I: MjMuMC4yMDAuMTg1
2017-09-24 17:21:37,346 - MainProcess(3984) - InstallDriver - adsk.dls.streamer.netlib - WARNING :: Failed to get public ip address <urlopen error [Errno 11001] getaddrinfo failed>
2017-09-24 17:21:37,347 - MainProcess(3984) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PU_I:
2017-09-24 17:21:37,347 - MainProcess(3984) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PR_I: MTkyLjE2OC4xLjI=
2017-09-24 17:21:37,579 - MainProcess(3984) - InstallDriver - adsk.dls.streamer.process - INFO :: Local DNS: U2VydmVyOiAgZGxpbmtyb3V0ZXINLCBBZGRyZXNzOiAgMTkyLjE2OC4xLjEN
2017-09-24 17:21:38,401 - MainProcess(3984) - InstallDriver - adsk.dls.streamer.netlib - WARNING :: Failed to get speed data <urlopen error [Errno 11001] getaddrinfo failed>
2017-09-24 17:21:38,401 - MainProcess(3984) - InstallDriver - adsk.dls.streamer.process - INFO :: Network Speed:
2017-09-24 17:21:38,401 - MainProcess(3984) - InstallDriver - adsk.dls.streamer.process - INFO :: Proxy enabled True
You are failing to reach certain URL and getting your IP address. Can you please review our network troubleshooting guide here with respect to proxies and ensure that the correct URL's are white listed. Also, if you have already done that, try resetting your router - it does seem strange that it cannot obtain your IP address.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 3 of 10
danielcorlett83
Sorry to say it but I'm not running a proxy. I have a laptop running fusion on the same network with no issues.
Message 4 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Hmmm, that's good to know. From the Fusion logs, Fusion believes you are under a proxy server which is most likely the issue. As you can see in the line below, denoted by the true flag:
Now, we can check this in a few ways. The first would be if you have Anti-Virus software, try to run that. Sometimes malware can setup a proxy without you knowing. Also, can you please use Control Panel and go to the Internet Options. Under the connections tab, you should see an option for Advanced LAN options. Is there a proxy set up here? Let me know if you need any help and perhaps we can take this offline and troubleshoot more in-depth.
James Youmatz
Message 5 of 10
danielcorlett83
OK so anti virus was run, with no threats. Checked the settings you recommended and they where off. I have also been through the trouble shooting guide on this forum and tried all of those ideas.
Dan
Message 6 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Do you have some time to connect this morning? If so, feel free to reach out to me at [email protected] so we can set something up. I'd love to take a first hand peek at your system and see why Fusion believes you have a proxy running.
James Youmatz
Message 7 of 10
danielcorlett83
Cool James, I have sent you a message.
Dan
Message 8 of 10
Same Problem here.
Message 9 of 10
having the same issue i have attached my log file please look into it.
Message 10 of 10
I had same issue. Turned firewall off and it worked. I was using ZoneAlarm.
