Problem every time i try to create a drawing sheet
dcAWMGX
Message 1 of 12
dcAWMGX
Almost every time i create a drawing sheet today i get this error and also my most of my pn numbers and dwg numbers fro manage wont show.
I have tried restarting fusion, the computer and tried to log out and into my fusion account again, nothing helps.
I really need help how to get this to run reliably.
Replies (11)
Message 2 of 12
dsouzasujay
Hi @dcAWMGX,
Please follow below link to troubleshoot updating fusion 360
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 3 of 12
ClintBrown3D
Hi @dcAWMGX
This error message is showing because your model contains newer information than the drawing. The prompt for the update is try to get you onto the same version.
Check that Fusion is not still downloading an update. If you are mid-update, once the new version is downloaded and you restart, this should resolve itself.
Another workflow that could cause this, is if the model was edited by someone using a pre-production build (like the insider program), and then you tried to do a drawing using a normal release build.
I hope that this helps.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
Message 4 of 12
dcAWMGX
I´m on version 2.0.12164, and fusion shows no updates.
Message 5 of 12
dcAWMGX
I´m the only one working on the files, jobstatus is empty and i save the part before i start a drawing sheet.
Message 6 of 12
rohit.bapat
Hello @dcAWMGX
We are sorry to know that you are facing this issue. Can you please share the f3z file with us? Steps to share the file can be found in this post.
It will help us reproduce and debug the issue faster.
Rohit Bapat
Sr. Product Owner
Message 7 of 12
dcAWMGX
as soon as i already created a drawing the warning donsen´t show up again on that part. only new parts.
Message 8 of 12
tarkeshwar.shah
Hi @dcAWMGX ,
Can you please share the diagnostic log to get more idea of the issue?
For help, below is the link about "How to collect the Diagnostic Log Files for Fusion 360".
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdc[…]l?_ga=2.5...
After sending the log file, you can try clear the local cache(as shown in below link) and your issue should get resolved.
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcar[…]&_ga=2.31...
Tarkeshwar Shah
Tech Lead, Fusion 360 Drawings
Message 9 of 12
dcAWMGX
HI,
Next time i get this problem i will post the log.
Message 10 of 12
tarkeshwar.shah
Thanks @dcAWMGX
Tarkeshwar Shah
Message 11 of 12
dcAWMGX
It just happend.
Message 12 of 12
tarkeshwar.shah
Thanks @dcAWMGX .
Did you tried doing the clear cache?
Tarkeshwar Shah
