Preview component description
acabazos
Observer Observer
acabazos
Observer
Observer
Hi everyone,
We are building a component library within fusion, on each component the name of the file is the PN and the description. We would like to split the description off the name of the file so it will be only the PN and have the description on the corresponding properties field. This way, when making a components list, we will be able to correctly see only the PN (without the description as it is right now) on the PN column, and the description on its corresponding column.
The reason of having the description on the name of the file along the PN is to better identify the component (some times preview doesn't help). Trying to get it correctly as stated before, we will lose the description insight. So, I'm looking to a way to show description on the preview or by hovering the mouse above the item...
If no way to have this option enabled somehow, is any way for a feature request?
Thanks a lot for your feedback.
BR
Abel
Phil.E
Can you please mockup a screenshot of what you are describing?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
