Post processing for CNC
JGilligA43QL
Observer Observer
JGilligA43QL
Observer
Observer
When I try and run the post processor button in fusion 360 to get the code for my CNC machine I get an error that fails to let the code compile. The error message is "Only two rotary axes can be active at the same time" does anyone know what this means or how I can fix it so I can compile the code for my CNC. Thanks
serge.quiblier
Hi @JGilligA43QL
It's hard to fix your issue with so few informations.
Which post processor are you using?
Have you selected a machine configuration file in your setup?
Have you created these elements yourself, or are you using items from the Fusion Library?
It seems that you are trying to use a machine with a kinematic containing more than 3 linear axis, and 2 rotary axis.
So, if you are trying to define a machine with 3 rotary axis, this is not supported by the post engine at the time.
ive us more information's to be more accurate in our explanations.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
