Post processing error
douwe_booij
Observer Observer
douwe_booij
Observer
Observer
I'm having trouble selecting a post processor for downloading an NC file for my smartbench.
After selecting either the yeti-tool smartbench or GRBL from the library im asked to copy it to "My Posts".
When I click "copy to my posts" I get the error message "invalid post processor"
I attached a video clarifying the issue.
Any help would be much appreciated.
viacheslav.shapilov
Hello.
There is a chance, that it failed to download the post from online post library. You can either download it manually from Post Library for Autodesk Fusion | Autodesk Fusion and import into your local library. Or you can disable online post library and use installed one:
Viacheslav Shapilov
Developer Technical Services
Autodesk Developer Network
douwe_booij
Observer
Observer
hello Viacheslav,
Downloading the post and importing it tot the local library did the trick
thanks for your solution!
