Possible to do a manual download and Product update?
I would like to access Fusion 360 at work to be able to save out STLs and print some projects on the 3D printer here.
However, it appears the proxy server at work won't allow auto-updates of Fusion. The version of I have installed at work is 2.0.5824 and if I try to open up a project I created at home, I get "Product Update Required. Fusion 360 can't open <File Name> which was persisted by version 2.0.6037 with your current software version 2.0.5824."
If I read thru the autodesk.webdeploy.streamer.log, it's pretty clear our proxy server isn't allowing a connection to be established to download the update.
Is it possible to manually download updates and apply them? I can't find any active links for this; every update link I try (such as "Update Software" under "Install Products" on "Get Your Autodesk Software Up & Running" just results in the dreaded "Page Not Found" message.
gasevsm
Please visit https://manage.autodesk.com/ and login with your AutodeskID. In there you should find all products and services you are entitled to, one of which should be F360. Hit the download butron to get latest stream update.
HTH,
Martin Gasevski | Fusion 360 Team Product Manager
Yes, that did it, Martin -- thanks for such a prompt response.
