Pocket issue - different sizes IRL to fusion drawing
rebecca.shillito
rebecca.shillito
Evening
I have been making some quick jigs up in Fusion, making use of the Nifty Slicer to expedite the process.
Please see the attached file.
The issue I am facing is that the milled pockets are about .5mm smaller on each edge than the drawing.
All other dimensions are as they should be.
I'm thinking this is the pocketing strategy that I am using but can't work it out.
Any help would be greatly appreciated.
Thank you all in advance!
HughesTooling
Could be defection depending on how ridgid you setup is. Try enabling finish cuts with a 0.1mm for the last cut.
Mark Hughes
Owner, Hughes Tooling
rebecca.shillito
Brilliant, thank you that worked a treat!
