Plane at Angle Bug
Plane at Angle Bug
wmhazzard
Advisor Advisor
Plane at Angle Bug
wmhazzard
When creating a plane at angle along a body edge, the plane moves in opposite direction to the rotate icon also, when the plane is set close to the desired angle, I typed in the angle but the plane moves to the opposite angle when the OK is clicked.
See the screencast and the attached model.
https://knowledge.autodesk.com/community/screencast/acbd6178-3f53-46fa-9e14-b16a402012fa
wmhazzard
Bump.
TrippyLighting
@Phil.E could you check this put please?
Phil.E
It's the draft command that does it. Here's the simplified timeline.
Without the draft command the work plane does not flip.
Workarounds
1. Place the work plane prior to the draft.
2. Or just supply a - sign to flip the resulting angle in the model attached.
(FUS-107663)
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
