Placement of a copied component based on a configuration parameter
leoLHPRD
leoLHPRD
I would like to place a copied component based on a configuration parameter. Is there a way to:
  1. Use a configuration parameter in a copy/move
  2. Attach a copied component to an offset plane (which I know can be set by a configuration parameter
davebYYPCU
  1. Use a configuration parameter in a copy/move  Joint
  2. Attach a copied component to an offset plane (which I know can be set by a configuration parameter. - Not possible - Joints use snap points, planes don’t have snap points
Might help….
leoLHPRD
Ok. I get it. Joint is what I should be using w/offset for the snap points and offsets which are configuration parameters, I think.
davebYYPCU
Yep.
