Perpendicular constraints bug
Hi there, I have a critical bug in the sketch of one of my designs.
When I draw two lines and set "perpendicular constraints" between them, they are not perpendicular. When I quote the angle it is different from 90° and more quotes of the same lines give different values.
Even if I set the horizontal/vertical constraints the two lines are not perpendicular to each other. It seems that world axes are not perpendicular between them.
I attach some screenshot to show you 3 different measurements of the same angle (watch the value in the bottom right corner of the window).
Thank you very much.
Frank.
jeff_strater
The sketch solver is only guaranteed to be accurate to 10-6, so these results are not completely unexpected.  However, let me look into this a bit more closely, because of the different values for different selections.  We have uncovered a few inaccuracies in how Measure reports values, and I suspect these may be related.
Jeff
Jeff Strater
Engineering Director
Thank you Jeff for your reply, but the problem I think it's a little more complicated. It's not easy to explain but I want to try...
Usually (thanks to God) when I make a new design and start a new sketch inside, I draw lines and put constraints without problems and without thinking so much. For example, I make a square, exit sketch, extrude it and I have a beautiful perfect box.
In some cases (and this is one of them) I draw a square putting constraints but, when I extrude it, the box is not orthogonal. A face is longer than the "parallel" face. Or if I draw 2 squares and extrude 2 boxes, when I select "parallel" faces of box 1 and box 2, in the bottom-right corner Fusion gives me an angle instead of the distance.
In conclusion, this problem sometimes causes me design bugs, difficult to discover. I would just like to make you understand that this is not my fussiness. Man Happy
Thank you again.
Frank
jeff_strater
It turns out that this is a bug in the Measure code.  The lines are definitely perpendicular, but when measuring between two entities, the graphical representation is used to calculate the distance/angle/etc.  The graphical representation is not quite as precise as the underlying curves/lines/etc.  So, when you select the line at different places along its length, you will get different measurements.  We will work towards fixing this problem, and thank you for pointing it out.
Jeff
Jeff Strater
I am also finding a problem, when i draw a sketch with the line tool, first horizontal then vertical i do not get a 90 degree square constraint shown? just the perpendicular marker?
I'm new to Fusion360 what am i missing?Screen Shot 2018-06-01 at 23.31.05.jpg
rishabh.bisht
This issue with the Measure command should be fixed with the November release. Please let us know if you still encounter this issue.
Thanks!
Rishabh Bisht
Product Owner
