Hello All,
I have imported a STEP file produced in Altium Designer of a reasonably simple PCB but which still contains a lot of bodies (4568 Unstiched + 121 Bodies). I have added this new fusion component into a simple assembly. When I try to move the imported PCB (called PowerBoard) the interface is very slugish).
The shared link is here: https://a360.co/2Itgm2C
I assume it is slow as Fusion has to move a very large number of bodies. However, if I pan/ rotate or movie the view in 3D space the performance is great. It only effects moving this particular component.
As I regularly integrate Electronics/ PCB from Altium Designer into my mechanical designs I would like to improve this performance significantly. Any help in doing this would be greatly appreciated.
Thanks in advance,
Graeme
