Perfect model one day - corrupted the next... any advice
HarrisonClassic
HarrisonClassic
So, has anyone seen this behavior?
I have a a reasonably heavy model. My standard practice is to do a "Compute All" then "Save" regularly. To give you an idea I've done this as an example around 40 times in the last 5 days.
Each time, "Compute All" reports no errors, "Save" reports no errors.
I shut down Fusion 360 about 30 mins ago then restarted, opened up the model and it now shows about 35 errors and 39 warnings.
In fact I need to go back about 30 versions in order to open the model and do a "Compute All" without getting errors.
I've uninstalled and reinstalled F360, but that did nothing.
What on earth can be causing this? Days and days of lost work.
Any help obviously appreciated.
David
David Harrison
Harrison Classic Boats
Win 10 / I7-11700K @ 4.9GHz / 64Gb RAM / SSD's
g-andresen
Did you use CLEAN UNINSTALL for this.
2. Please share the file.
File > export > save as f3d on local drive  > attach it to the next post
günther
HarrisonClassic
Yes I did Guenther, have sent you a DM.
David
David Harrison
