Pattern On Path failing when patterning a feature
BHWeaver
BHWeaver
I'm following a tutorial that uses dogbones and when I try to pattern a feature(a cut) it fails to space properly and sometimes it fails all together. Any idea where I'm going wrong? I tried the same process repeatedly with the same result and then I tried it with a component and it worked perfectly every time.
jhackney1972
It seems weird to me also but use "Faces" instead of "Features" and it works OK.  You can select all the faces with a window if you would like.
John Hackney, Retired
BHWeaver
Thank you,
That worked I spent  4-5 hours checking different settings and combing the forums to see if there was a solution I tried Faces like you showed and it worked perfectly.
