Part Search Error
Part Search Error
KneubaeckerS7UG4
Message 1 of 12
Part Search Error
KneubaeckerS7UG4
     Upon trying to search for a past model and program, on multiple occasions instead of finding the part or even running a search, I receive this drop down with various lines of code. The only way to rectify this issue is to restart fusion, which when having multiple files open it can become cumbersome. I'm assuming this is some sort of bug because there is no rhyme or reason for why this happens.
Replies (11)
Message 2 of 12
KneubaeckerS7UG4
this is an ongoing issue
Message 3 of 12
jodom4
@jeff_strater, can you take a look at this one?
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
Message 4 of 12
saketsatta
Hi @KneubaeckerS7UG4 ,
I'm sorry to see that you are running into this issue. The next time it happens, could you please collect the diagnostic logs and post them here or send them to saket dot satta at autodesk.com? It will help us to diagnose the problem.
Here are instructions on collecting log files: https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Saket
Message 5 of 12
KneubaeckerS7UG4
Log files attached
Message 6 of 12
KneubaeckerS7UG4
I have attached the log files below thanks
Message 7 of 12
saketsatta
Thank you for providing these logs. I have contacted the relevant teams and I will reply as soon as we find a resolution.
Saket Satta
Fusion 360 development
Message 8 of 12
KneubaeckerS7UG4
Message 9 of 12
KneubaeckerS7UG4
In case this was in the process of being fixed I just wanted to send log files again from the issue happening today as well. Thanks
Message 10 of 12
saketsatta
Thanks again for the logs. The development team is looking into it, here is a ticket id for future reference: https://jira.autodesk.com/browse/ATEAM-32523
Saket
Message 11 of 12
matt.pooley
Hi All,
We might have found a workaround for this issue while we work on a full fix. If you use the down arrow next to the search entry field and select 'All Data', and then run that search, it should initialize the system so that subsequent project searches work as expected. Unfortunately this workaround would need to be triggered once a day, but if it works for you please let us know so we can confirm that what we are planning to change will fix this fully.
Matt Pooley
On Behalf of the Fusion Dev Team
Message 12 of 12
KneubaeckerS7UG4
This workaround is functional until a full fix is made. Thank you!
