Parametric Patterns of Assemblies
rbameMA3EK
rbameMA3EK
When I pattern an assembly none of the constraints or the axis defines the new components. Each component in the assembly is also free to move. Is there a way to bound the newly patterned component to the pattern master? For example, Assembly 1 is patterned 1" on an edge. After the pattern is created, the assembly and subcomponents can move freely. Why even pattern a component or assembly and just use copy / paste?
We are being forced to use Fusion now that HSM is being discontinued and these types of issues make it impossible to compare to SolidWorks.
dsouzasujay
Hi @rbameMA3EK ,
What you are seeing is a current limitation of component patterns in Fusion.
A Component Pattern controls the initial placement, spacing, quantity, and direction of the patterned components, but it does not automatically duplicate the joints or assembly relationships that constrain the original occurrence to the surrounding assembly. This is why a patterned component can still have degrees of freedom after the pattern is created.
For this type of workflow, there are a couple of options:
  • If the components within your subassembly should always move as one unit, define the relationships inside that subassembly, or use a Rigid Group, then pattern the subassembly rather than the individual components.
  • If you need each repeated assembly to retain its relationship to the surrounding geometry, I recommend Assemble > Duplicate With Joints. This command duplicates the component together with its attached joints and lets you place each new instance using joint locations.
  • You can also pattern the components and then add As-Built Joints or a Rigid Group afterward, although that is less convenient for a fully parametric assembly.
There is still value in Component Pattern compared with Copy/Paste because the quantity, spacing, direction, and suppression of instances remain controlled by a single pattern feature. However, I agree that not being able to automatically propagate the required assembly relationships can be limiting, particularly when coming from assembly workflows in SolidWorks.
If you can share a simplified F3D/F3Z showing the assembly you are trying to pattern, I would be happy to look at the structure and suggest the most reliable Fusion workflow for it.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
rbameMA3EK
This is a major limitation and frustrating. No other CAD software like SolidWorks has this limitation. A pattern should be defined by the axis, rotation or other feature controlling the pattern. That is the constraint.
akash.nawghare
HI @rbameMA3EK
You're right that Fusion doesn't auto-propagate assembly constraints through a Component Pattern the way SolidWorks does — that's a known limitation.
Best workaround for a parametric pattern:
  1. Create a container component for the pattern.
  2. Insert your seed assembly/component inside it and Ground to Parent (GTP).
  3. Run Pattern Component on the seed — all instances inherit GTP and stay fixed relative to the container.
  4. Joint the container once to the parent assembly (not each instance).
Alternatives:
  • If the subassembly should move as one rigid unit → define relationships inside it, then pattern the whole subassembly.
  • If each copy needs its own joints to surrounding geometry → use Assemble → Duplicate With Joints.
  • Fixed count only → Rigid Group all instances after patterning (breaks when count changes).
Pattern still beats copy/paste because count, spacing, and suppression stay parametric — you just need to lock instances with GTP or a rigid group first. Happy to suggest a workflow if you share a simplified F3D.
Did you find this post helpful? Feel free to Like this post.
Did your question get successfully answered? Then click on the ACCEPT SOLUTION button.
Akash Nawghare
Autodesk Fusion
rbameMA3EK
When will this limitation be corrected so that we don’t have to use this clunky work around?
