Parametric Logo Size
theandydove
Observer Observer
theandydove
Observer
Observer
I cannot for the life of me figure out how to incorporate a logo extruded onto a surface that gets larger or smaller based on parametrics?
Other than, of course, having the logo at the smallest size the face would be.
Thanks in advance.
jhackney1972
Please attach your model or at least provide a screen capture of what you desire.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it. If needed, ZIP a F3Z file.
John Hackney, Retired
jeff_strater
assuming that your logo is a sketch, you can use the "scale entire sketch on first dimension" setting in preferences.  This capability allow the entire sketch to be scaled based on just a single dimension.   This dimension can be then plugged into the rest of your parametric design.  See the video below
(view in My Videos)
Jeff Strater
Engineering Director
theandydove
Observer
Observer
Thank you Jeff, that solution works if type a dimension, however if I use a parametric value it only changes the outside rectangle and not the logo within.
g-andresen
Please share the file for reply
File > export > save as f3d on local drive > attach to post
günther
jeff_strater
oh wow.  @theandydove you are correct.  I had to test that to believe it.  Definitely a bug.  I will report that.  I suspect that this has always been a problem (as long as the "scale entire sketch" option has been there).  Thank you for reporting it.
[edit]  created bug FUS-204442 for this issue
Jeff Strater
