Parametric bolt.
Parametric bolt.
LiveLover
Parametric bolt.
LiveLover
Hello!
I'm using MMaster-carr catalog and it is rather useful.
But can we drive screw length based on User Parameters?
I can imagine my own parametric bolt models and parameters in a master file.
Are there other possibilities? Substitute one component by a new one with very same topology preserving all the joints, etc?
I will be grateful for any suggestions! Links are highly welcome!
Thank you!
davebYYPCU
But can we drive screw length based on User Parameters?  Not as supplied.
McMaster stuff - no joints.
jeff_strater
I suspect that you need two capabilities that Fusion does not have today, but are both in development:  Configurations, and Replace Component.  Configurations will let you drive a "family" of bolts from a single design (resulting in different bolt lengths/threads, heads, etc - it would be up to you to determine what is configurable).  Replace Component will let you swap out one bolt family instance for another, preserving whatever references are possible to preserve.
Jeff Strater
Engineering Director
